Forums / General Moped Discussion
Re: What you ought to do...!!
Mike Alanko (northernmike) — Jun 30, 2009 11:45PM
For range equations I will have to do some metrics.
I would _guess_ that for 10 miles you'll need about 30Ah (That's useable discharge, not nominal) ...
But that's a guess. 40 might be more reasonable, 20 might be feasable. A lot depends on terrain, wind, all up weight, acceleration, speed. Better to have some in reserve, that way you're not drawing to high a "C" factor.
If you're hypermiling it range goes WAY up. Blasting sucks amps, of course. Acceleration is never free.
There's this awesome (and Canadian made) gadget called the "Cycle Analyst" I have to pick up. Shows amps, volts, watts, speed, distance, in real time, plus cumulative, gives you a "fuel gauge" of sorts, recalls max draws, total amps used, watt-hours / mile, etc etc... another $175 I have to find! Totally worth it.
I'm also working on a small+light onboard charger that does it's work in an 8-hour workday kind of fashion.
Most available lithium chargers like to cycle in about 3.5hrs, so this shouldn't be a problem.
My work is about the same distance away, my intent is to have a finished product that I can drive into the parking garage, switch off, pull a cord out of and plug in to the wall, and leave it to charge.
A low-power electric Vespa in Maine was doing a similar commute on 22Ah of SLAs - at about 30mph. I think
Was that Elliot or Noah L inquiring? Did the author / user stuff get confused?
Seeing as this mount was the first one, changes are possible.
Anything you guys would like to see on a "production" version?
  Electrobecane Mike Alanko 06/28/09 08:28PM
  Re: Electrobecane Mars™   06/28/09 08:32PM
  Re: Electrobecane Grey L 06/28/09 08:35PM
  Re: Electrobecane bk 06/28/09 08:50PM
  Re: Electrobecane mauvescorpion 06/28/09 08:52PM
  Re: Electrobecane Jesse -B 06/28/09 09:03PM
  Re: Electrobecane Southern Dandy JCams 06/28/09 09:05PM
  Re: Electrobecane Robert Rosselit 06/28/09 09:08PM
  Re: Electrobecane Mouth 06/28/09 10:31PM
  Re: Electrobecane Mike Alanko 06/28/09 11:23PM
  Re: Electrobecane Mike Alanko 06/28/09 11:32PM
  Re: Electrobecane Zeke 06/28/09 11:44PM
  Re: Electrobecane Takin A Schmitz 06/29/09 12:21AM
  Re: Electrobecane keller_stephen 06/29/09 02:37AM
  Re: Electrobecane Al . 06/29/09 03:13AM
  Re: Electrobecane Zap Heteroped 06/29/09 03:39AM
  Re: Electrobecane rockles 06/29/09 03:47AM
  Re: Electrobecane jims72 aka king'o'DUSTMITES 06/29/09 06:45AM
  Re: Electrobecane Mike Alanko 06/29/09 07:19AM
  Re: Electrobecane Ryan B 06/29/09 03:38PM
  Re: Electrobecane black twingle 06/29/09 03:50PM
  Re: Electrobecane Al . 06/29/09 04:33PM
  Re: Electrobecane finny 06/29/09 05:33PM
  Re: Electrobecane Mike Alanko 06/29/09 05:50PM
  Re: Electrobecane Mike Alanko 06/29/09 06:00PM
  Re: Electrobecane Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 06/29/09 06:49PM
  Re: Electrobecane rthor 06/29/09 07:43PM
  Re: Electrobecane Nate Bandit 06/29/09 11:47PM
  battery? King Bengry 06/30/09 12:47AM
  Re: battery? adam as adam 06/30/09 12:53AM
  Re: battery? motobee 06/30/09 01:04AM
  Re: battery? vic 06/30/09 01:09AM
  Re: battery? max 06/30/09 03:08AM
  Re: battery? Mike Alanko 06/30/09 06:52AM
  What you ought to do...!! Al . 06/30/09 10:13AM
  Re: What you ought to do...!! Leon Swarmer 06/30/09 03:12PM
  Re: What you ought to do...!! liam 06/30/09 03:38PM
  Re: What you ought to do...!! Mike Alanko 06/30/09 05:12PM
  Re: What you ought to do...!! emmanuel lewis 06/30/09 10:06PM
  Re: What you ought to do...!! Elliot 06/30/09 11:04PM
  Re: What you ought to do...!! Mike Alanko 06/30/09 11:45PM
  Re: What you ought to do...!! elliot 07/01/09 12:09AM
  Re: What you ought to do...!! JJ 07/01/09 12:33AM
  Re: What you ought to do...!! Noah K 07/01/09 01:17AM
  Re: What you ought to do...!! Mike Alanko 07/01/09 07:31AM
  Re: What you ought to do...!! King Bengry 07/01/09 09:12AM
  Re: What you ought to do...!! Mike Alanko 07/01/09 10:44AM
  Re: What you ought to do...!! Jesse -B 07/01/09 10:45AM
  Production preparations Mike Alanko 07/01/09 11:11AM
  Re: Production preparations Al . 07/01/09 11:17AM
  Re: Production preparations Mike Alanko 07/01/09 11:36AM
  Re: Production preparations Al . 07/01/09 11:41AM
  Re: Production preparations Mike Alanko 07/01/09 11:56AM
  Re: Production preparations elliot 07/01/09 02:48PM
  Re: Production preparations black twingle 07/01/09 03:24PM
  Batteries. Mike Alanko 07/01/09 04:01PM
  Mount updates Mike Alanko 07/01/09 04:06PM
  Thoughts on batteries. Mike Alanko 07/01/09 04:12PM
  Battery shopping Mike Alanko 07/01/09 07:41PM
  Re: Battery shopping Mike Alanko 07/01/09 08:17PM
  Re: Battery shopping Mike Alanko 07/01/09 08:20PM
  Re: Electrobecane Zap Heteroped 07/01/09 08:21PM
  Re: Electrobecane Los Dean 07/01/09 08:44PM
  Re: Electrobecane Mike Alanko 07/01/09 10:10PM
  Re: Electrobecane Cappy 07/02/09 05:17AM
  Re: Electrobecane Charlie BUZZARD 07/02/09 02:36PM
  Weather resistance Mike Alanko 07/02/09 06:24PM
  Anodizing progress. Mike Alanko 07/02/09 06:34PM
  put this in the wiki rei 07/02/09 10:02PM
  More riding Mike Alanko 07/02/09 10:57PM
  Re: More riding JJ 07/03/09 01:16AM
  Re: More riding Mike Alanko 07/03/09 07:24AM
  Battery update Mike Alanko 07/05/09 08:24AM
  Re: Battery update Drew Gulliver 07/05/09 01:41PM
  Dude... DrunkSkunk 07/05/09 03:05PM
  Re: Dude... Chris 07/05/09 05:55PM
  YouTube enroute Mike Alanko 07/05/09 06:45PM
  Re: YouTube enroute Mike Alanko 07/05/09 08:33PM
  Re: Electrobecane rthor 07/05/09 11:19PM
  Re: YouTube enroute Mike Alanko 07/05/09 11:19PM
  Re: YouTube enroute Mike Alanko 07/06/09 12:02AM
  Re: YouTube enroute Pete Daddeo 07/06/09 03:08AM
  Re: YouTube enroute King Bengry 07/06/09 07:08PM
  Battery capacity Mike Alanko 07/06/09 07:27PM
  Re: Battery capacity Cm 07/06/09 08:32PM
  Motor mount production news Mike Alanko 07/06/09 08:34PM
  Re: Motor mount production news Mike Alanko 07/13/09 07:16PM
Click here to login.
