Forums / General Moped Discussion
dmp stuffed crank bearing color
michael hardy (mustang_hardy) — Jun 14, 2009 11:25AM
as you can see in the pic, the right side of the con rods bottom is blued..now, the stuffing was already missing on the left, so i left it as is..i will be removing the smidge of a piece on the right side to match the other side..this kit has around 1500 or so well earned hard ridden blasting i'm faster than you miles on it....i like ta ride..my questions are... a) could it be a premix issue?? i do 50:1, plus another puch gas cap full with 93 octane.. lucas oil.
b)or just because that lil bit of stuffn didn't let enough lubercant through..
the rest of the crank and engine looks great.the piston is perfect too..
my 1978 Puch
alukitty
21mm phbg
new bearings and seals
case matched, ported exhaust,intake
dmp stuffed crank
malossi 4 petal
techno estroil
55mph down slight hill 13x36
i pulled the engine apart to do some more porting and this is the only issue i have thankfully.. thank you in advance for your advice....
  dmp stuffed crank bearing color michael hardy 06/14/09 11:25AM
  Re: dmp stuffed crank bearing color Stoops Stoops 06/14/09 02:51PM
  Re: dmp stuffed crank bearing color michael hardy 07/03/09 02:49PM
Click here to login.
