Re: electric
The largest brake rotor that will fit is a 203mm. I sandwhiched the sprocket with the offset (1/4") to the inside. The stock brake caliper is riding about 3/4 of an inch above the sprocket, so I can't go much bigger than 30 tooth without cutting the mounting bracket for the brake off. I DON'T WANT TO DO, I started to but changed my mind when I came up with this solution.
| Subject | Written By | Posted |
