Forums / General Moped Discussion
Carb (timing) adjustment Screw Location?
moped_mom (moped_mom) — Aug 01, 2007 11:03PM
This is a very dumb question- forgive...
Where is the carb (timing) adjustment screw located on a Tomos Sprint? I have this diagram in my manual that says, "7A" and points to a screw that has a spring on the base, located under the choke lever...is that it?? The manual doesn't seem to have actually indicated what their arrow pointing to that screw with the spring ("7A") is, but it does say if it idles poorly to try adjusting the carb adjustment screw, like you all suggested.
Thanks!
  Carb (timing) adjustment Screw Location? moped_mom 08/01/07 11:03PM
Click here to login.
