Re: Peter's motobecane engine mounts
save the hassle and use the pep bois bushings. theyre perfectly sized, and come with nice washers to help you do the job. literally all i needed was a knife, a dremel (could use the knife, if you're badass enough or in the woods or something), a clamp, and the washers that come with. Pop the swivel sleeves in there using the clamp after dremeling out a bit. knife out the old dry rotted rubber get out all of it. use the washers to get equal pressure distribution and clamp the new bushing into the hole. wonderful
