Forums / General Moped Discussion
Re: Peter's motobecane engine mounts
tortuga2 (tortuga2) — Oct 03, 2007 08:33PM
I happened to discover the same solution using exactly the same bushings, installation was a little different though.
Had always been leary of removing the bushings from the frame (cuz I don't have the fancy NOS puller) so I "cored" out the old rubber using a HFT hole saw withe pilot drill removed then scraped the inner sleeve clean. Loosely install the urethane bushings in the metal shell (still in the frame) and with a big ass c-clamp, press the inner sleeve into the urethane bushing. As the bushing expands it will snug itself inside the shell in the frame. Did this mod about 6 mos ago on my daily rider ('77 50V) and haven't had an engine mount related problem since (I do about 100-125 miles a week).
I tried machining my own, skateboard truck rubbers (worked ok & were readily available) but the urethane sway bar bushings kill 'em all.
It's a bitchin' solution to a nightmare design flaw. Good job Peter.
  Peter's motobecane engine mounts Peter 07/04/07 09:04PM
  Re: Peter's motobecane engine mounts Peter 07/04/07 09:07PM
  Re: Peter's motobecane engine mounts ken 07/04/07 10:26PM
  Re: Peter's motobecane engine mounts keller_stephen 07/05/07 03:50AM
  Re: Peter's motobecane engine mounts Review ChadM 03/09/09 03:28AM
  Re: Peter's motobecane engine mounts Review ChadM 03/09/09 04:20AM
  Re: Peter's motobecane engine mounts craigery 07/04/07 10:26PM
  Re: Peter's motobecane engine mounts Fifty2One 07/04/07 11:32PM
  Re: Peter's motobecane engine mounts vic 07/04/07 11:40PM
  Re: Peter's motobecane engine mounts Joel Corvine 07/04/07 11:42PM
  Peter's motobecane engine mounts brystheguy 07/05/07 12:08AM
  Re: Peter's motobecane engine mounts peter 07/05/07 12:11AM
  Re: Peter's motobecane engine mounts tortuga2 10/03/07 08:33PM
  Re: Peter's motobecane engine mounts andrewhed 07/05/07 12:18AM
  Re: Peter's motobecane engine mounts peter 07/05/07 12:25AM
  Re: Peter's motobecane engine mounts andrewhed 07/05/07 01:12AM
  Re: Peter's motobecane engine mounts Anthony K 07/05/07 09:27AM
  Re: Peter's motobecane engine mounts No Ped Steve 12/04/08 07:14PM
  Re: Peter's motobecane engine mounts maitland 07/05/07 01:57AM
  Re: Peter's motobecane engine mounts mabecane1978 07/05/07 08:57AM
  Re: Peter's motobecane engine mounts JCampbell 07/05/07 09:40AM
  Peter's motobecane engine mounts jerry76 07/05/07 12:21PM
  Re: Peter's motobecane engine mounts peterman 07/06/07 01:34AM
  Re: Peter's motobecane engine mounts Brett Walker 07/06/07 01:42AM
  Re: Peter's motobecane engine mounts peterman 07/06/07 01:51AM
  Re: Peter's motobecane engine mounts Mike Bartell 07/06/07 02:16AM
  Re: Peter's motobecane engine mounts Creature Van 10/03/07 08:45PM
  Re: Peter's motobecane engine mounts Bret Hoffman 10/03/07 09:04PM
  Re: Peter's motobecane engine mounts jimbo 10/04/07 02:46AM
  Re: Peter's motobecane engine mounts steve 10/03/07 09:20PM
  Re: Peter's motobecane engine mounts Graham Motzing 10/04/07 02:53AM
  Re: Peter's motobecane engine mounts peter 10/04/07 02:59AM
  Re: Peter's motobecane engine mounts Ratbiker. 10/04/07 03:04AM
  Re: Peter's motobecane engine mounts steve 10/16/07 06:15PM
  Re: Peter's motobecane engine mounts peter 10/16/07 06:25PM
  Re: Peter's motobecane engine mounts Arran 10/16/07 08:00PM
  Re: Peter's motobecane engine mounts Erin L 10/16/07 10:46PM
  Re: Peter's motobecane engine mounts Graham Motzing 10/16/07 08:24PM
  Re: Peter's motobecane engine mounts peter 10/16/07 09:52PM
  Re: Peter's motobecane engine mounts Arran 10/16/07 09:55PM
  Re: Peter's motobecane engine mounts Graham Motzing 10/16/07 10:44PM
  Re: Peter's motobecane engine mounts Arran 10/16/07 11:03PM
  Re: Peter's motobecane engine mounts peter 10/16/07 10:45PM
  Re: Peter's motobecane engine mounts Graham Motzing 10/17/07 02:36AM
  Re: Polyurethane Mix Arran 10/17/07 04:53PM
  Re: Polyurethane Mix Bert 10/17/07 05:53PM
  Re: Peter's motobecane engine mounts JCampbell 10/17/07 10:51AM
  Re: Peter's motobecane engine mounts steve 10/17/07 11:08AM
  Re: Peter's motobecane engine mounts Crackstar X 10/17/07 12:04PM
  Re: Peter's motobecane engine mounts JCampbell 10/17/07 12:17PM
  Re: Peter's motobecane engine mounts Peter 10/17/07 01:14PM
  Re: Peter's motobecane engine mounts JCampbell 10/17/07 01:29PM
  Re: Peter's motobecane engine mounts Bert 10/17/07 04:15PM
  Re: Peter's motobecane engine mounts steve 10/17/07 04:57PM
  Re: Peter's motobecane engine mounts Bert 10/17/07 05:18PM
  Re: Peter's motobecane engine mounts JCampbell 10/17/07 05:23PM
  Re: Peter's motobecane engine mounts Bert 10/17/07 05:30PM
  Re: Peter's motobecane engine mounts steve 10/17/07 05:43PM
  Re: Peter's motobecane engine mounts steve 10/17/07 05:45PM
  Re: Polyurethane Mix Daniel 03/23/08 05:22PM
  Re: Polyurethane Mix Bert 10/17/07 05:57PM
  Re: Polyurethane Mix peter 10/17/07 07:11PM
  Re: Polyurethane Mix steve 10/17/07 09:24PM
  Re: Polyurethane Mix Bert 10/17/07 09:58PM
  Re: Polyurethane Mix steve 10/17/07 10:20PM
  Re: Polyurethane Mix peter 10/18/07 05:19AM
  Re: Polyurethane Mix JCampbell 10/18/07 10:01AM
  Re: Polyurethane Mix steve 10/18/07 12:34PM
  Re: Polyurethane Mix JCampbell 10/18/07 12:37PM
  Re: Polyurethane Mix Bert 10/20/07 08:57PM
  Re: Polyurethane Mix peter 10/20/07 09:27PM
  Re: Polyurethane Mix Bert 10/20/07 10:07PM
  Re: Polyurethane Mix Arran 10/21/07 02:30AM
  Re: Polyurethane Mix steve 10/20/07 10:29PM
  Re: Polyurethane Mix peter 10/21/07 02:23AM
  Re: Polyurethane Mix Bert 10/21/07 10:22AM
  Re: Polyurethane Mix steve 10/21/07 11:38AM
  Re: Polyurethane Mix Bert 10/21/07 01:25PM
  Re: Polyurethane Mix JCampbell 10/22/07 10:01AM
  Re: Polyurethane Mix Terry 10/27/07 08:51PM
  Re: Polyurethane Mix Terry 10/28/07 09:18PM
  Re: Polyurethane Mix JCampbell 10/22/07 10:03AM
  Re: Polyurethane Mix JCampbell 10/22/07 10:04AM
  Re: Polyurethane Mix keller_stephen 10/29/07 02:28AM
  Re: Polyurethane Mix steve 10/22/07 10:26AM
  Re: Polyurethane Mix Bert 10/22/07 11:39AM
  Re: Polyurethane Mix JCampbell 10/22/07 12:06PM
  Re: Polyurethane Mix Chad Burke 10/23/07 07:52AM
  mounts Bert 10/27/07 08:18PM
  Re: Polyurethane Mix steve 10/27/07 09:17PM
  Re: Polyurethane Mix peter 10/27/07 11:28PM
  Re: Polyurethane Mix Loren 06/16/08 01:39AM
  Re: Polyurethane Mix Bert 10/28/07 12:26PM
  Re: Polyurethane Mix steve 10/28/07 09:42PM
  Re: Polyurethane Mix finny 03/23/08 11:07PM
  Re: Polyurethane Mix steve 03/23/08 11:11PM
  Re: Polyurethane Mix Daniel 03/24/08 03:45AM
  Re: Polyurethane Mix finny 03/24/08 11:19AM
  Re: Polyurethane Mix Cory K 07/22/08 07:25PM
  Re: Polyurethane Mix Mike Alanko 07/22/08 07:44PM
  Re: Polyurethane Mix Jay 07/22/08 07:47PM
  Re: Polyurethane Mix steve 07/23/08 01:40AM
  Re: Polyurethane Mix Mike Alanko 07/23/08 02:01AM
  Re: Peter's motobecane engine mounts mopedjay 07/23/08 02:08AM
  Re: Peter's motobecane engine mounts sheila 07/23/08 02:09AM
  Re: Peter's motobecane engine mounts mopedjay 07/23/08 02:19AM
  Re: Peter's motobecane engine mounts bert 07/23/08 10:01AM
  Re: Peter's motobecane engine mounts Bret Hoffman 07/23/08 03:45PM
  Re: Peter's motobecane engine mounts pepilapeau 08/27/08 10:25PM
  Re: Peter's motobecane engine mounts saturn 08/27/08 11:43PM
  Re: Peter's motobecane engine mounts educatetheyouth 08/28/08 07:59AM
  Re: Peter's motobecane engine mounts Paulvolio 08/28/08 11:18AM
  Re: Peter's motobecane engine mounts Jeff 12/03/08 07:39PM
  Re: Peter's motobecane engine mounts peter 12/03/08 08:54PM
  Re: Peter's motobecane engine mounts Southern Dandy JCams 12/03/08 09:08PM
  Re: Peter's motobecane engine mounts elliot 12/03/08 09:08PM
  Re: Peter's motobecane engine mounts Jeff 12/04/08 01:23PM
  Re: Peter's motobecane engine mounts Southern Dandy JCams 12/04/08 01:49PM
  Re: Peter's motobecane engine mounts Tony Plush 12/04/08 02:30PM
  Re: Peter's motobecane engine mounts nick 12/26/08 09:14PM
  Re: Peter's motobecane engine mounts PAULVOLIO 12/26/08 09:26PM
  Re: Peter's motobecane engine mounts jaym 12/26/08 09:31PM
  Re: Peter's motobecane engine mounts sheila 12/26/08 09:36PM
  Re: Peter's motobecane engine mounts Motobee Goode 02/22/09 05:06AM
  Re: Peter's motobecane engine mounts Leo Heyman 02/22/09 10:46AM
  Re: Peter's motobecane engine mounts Gym-Me IRE 02/22/09 11:43AM
  Peter's motobecane engine mounts Review Jesse Stephenson 02/22/09 11:15PM
  Re: Peter's motobecane engine mounts Review peter 02/22/09 11:58PM
  Re: Peter's motobecane engine mounts Review Jesse Stephenson 02/23/09 12:07AM
  Re: Peter's motobecane engine mounts Review Graham Motzing 02/23/09 12:24AM
  Re: Peter's motobecane engine mounts Review peter 02/23/09 12:27AM
  Re: Peter's motobecane engine mounts Review Motobee Goode 02/23/09 01:18AM
  Re: Peter's motobecane engine mounts Review peter 03/09/09 03:51AM
  Re: Peter's motobecane engine mounts Review Justina -+:| 10/06/09 01:06PM
  Re: Peter's motobecane engine mounts Review Dwight 10/06/09 04:23PM
  Re: Peter's motobecane engine mounts Review peter 10/06/09 04:40PM
  Re: Peter's motobecane engine mounts Review Ryan B 10/06/09 07:01PM
  Re: Peter's motobecane engine mounts Review Mick Baltards 10/07/09 10:54AM
  Re: Peter's motobecane engine mounts Review timo 10/07/09 11:06AM
  Re: Peter's motobecane engine mounts Review Downhill Nater 09/30/10 04:17AM
  Re: Peter's motobecane engine mounts Review briton bees 09/30/10 08:29AM
  Re: Peter's motobecane engine mounts Review jOHNNYdOUBE 09/30/10 10:46AM
  Re: Peter's motobecane engine mounts Review ChadM 09/30/10 10:59AM
  Re: Peter's motobecane engine mounts Review Phil Norath [MMP] 09/30/10 04:38PM
  Re: Peter's motobecane engine mounts Review Adam 10/12/10 01:41PM
  Re: Peter's motobecane engine mounts Review WillD SWOOP 10/12/10 01:52PM
  Re: Peter's motobecane engine mounts Review cristian 01/24/11 01:04AM
  Re: Peter's motobecane engine mounts Review Gary Herrisch 01/24/11 01:18AM
  Re: Peter's motobecane engine mounts Review deathplaybanjo 01/24/11 01:24AM
  Re: Peter's motobecane engine mounts Review PAULVOLIO 01/24/11 08:57AM
  Re: Peter's motobecane engine mounts Review IRE Rick 01/25/11 09:45PM
  Re: Peter's motobecane engine mounts Review Phil Norath [MMP] 01/26/11 12:55AM
  Re: Peter's motobecane engine mounts Review scooterstl 01/26/11 01:21AM
  Re: Peter's motobecane engine mounts Review scooterstl 01/26/11 01:22AM
  Re: Peter's motobecane engine mounts Review scooterstl 01/26/11 01:26AM
  Re: Peter's motobecane engine mounts Review scooterstl 01/26/11 01:30AM
  Re: Peter's motobecane engine mounts Review scooterstl 01/26/11 01:33AM
  Re: Peter's motobecane engine mounts Review Phil Norath [MMP] 01/26/11 01:25AM
  Re: Peter's motobecane engine mounts Review Phil Norath [MMP] 01/26/11 01:39AM
  Re: Peter's motobecane engine mounts Review Pusher Aaron 01/26/11 01:27PM
  Re: Peter's motobecane engine mounts Review scooterstl 01/26/11 02:02PM
  Re: Peter's motobecane engine mounts Review IRE Rick 01/26/11 08:01PM
  Re: Peter's motobecane engine mounts Kurt Muzio 07/03/11 04:36PM
Click here to login.
