Re: Peter's motobecane engine mounts
i put the inner sleeve in first. This caused the entire bushing to get larger overall, leaving it needing to get "pressed" into the outer sleeve using a hammer.
im pretty sure all swaybar endlinks use the same bushings. these werent behind the counter or anything, just chillin in the aisle.
