Forums / General Moped Discussion
Peter's motobecane engine mounts
Peter ( peter) — Jul 04, 2007 09:04PM
Problem:
Motobecanes rely heavily on their engine mounts since the engine moves as it variates. They act as a pivot point and get put under heavy load. Every single motobecane i have seen (even my 40tl which had 301 miles on it and barn kept) has had dry rotted engine mounts.
What about aftermarket or NOS?:
The aftermarket 3rd party mounts are absolute shit. They fail rapidly and aren't worth buying. NOS are expensive, hard to get, and are still 30 year old rubber.
My objective:
To find a solution to this problem using readily available materials and minor labor.
Solution:
First, i tried packing the old mounts; old rubber and all, with black windshield adhesive which is urethane based. This works well, but i knew i couldn't run my new powerful kitted motobecane with band-aid'd mounts. So i set out to find a new solution. These moped mounts are just like car engine mounts. Rubber, with metal bushings in them which get pressed into the frame, then have metal sleeves where the engine mounting bolt goes through. Back when i used to build record breaking honda civics, i replaced all my engine mounts with hard urethane to keep the power to the wheels and not being lost in the flimsy stock mounts designed for comfort.
While daydreaming in AutoZone one day i had looked at a set of Energy Suspension Performance Endlink Bushings for factory sway bar replacement. Made of urethane, they are stiff and tough. These were the perfect size and shape to replace the rubber in the mounts. I bought them and got em home. $11.99 at every AutoZone. Includes 8 bushings, or enough for 4 sets of motor mounts.
Then, i pulled the factory mounts out of a beater frame to test it out using my O.E. vintage motobecane engine mount pulling tool $$$$$$$$$$$
Then, doing what i had to do with some old honda control arms with stuck bushings... I put the mounts in a fire to burn out the old rubber.
After the fire died down, i scraped off all the residue, and cleaned them up with a rag. These look nice!
Here is where i had to get creative. The endlink bushings aren't quite big enough to press firmly into the outer sleeve of the mount. So what i did was JAM THE FUCK out of the inner sleeve into the mount. I had to drill/dremel open the hole in the bushing to get that shit to fit. Remember, you want it to be as tight tight tight, because you are relying on the expansion of the entire bushing you get when forcing the metal sleeve into the center. This expansion helps it fit tight into the big outer sleeve. I used a hammer to press the bushings in. They fit really nice.
Then, the inner sleeve is longer than the rest of the bushing, so i grinded that shit down to be the same length, and will use metal or nylon spacers to fill in that area missing. I guess you could skip this step...
Reinstall!
Gonna test another set of these on my daily rider tomorrow. This is something most everyone can do. I used a bench grinder, hammer, drill, dremel, and basic hand tools.
Enjoy!! Keep Riding!
  Peter's motobecane engine mounts Peter 07/04/07 09:04PM
  Re: Peter's motobecane engine mounts Peter 07/04/07 09:07PM
  Re: Peter's motobecane engine mounts ken 07/04/07 10:26PM
  Re: Peter's motobecane engine mounts keller_stephen 07/05/07 03:50AM
  Re: Peter's motobecane engine mounts Review ChadM 03/09/09 03:28AM
  Re: Peter's motobecane engine mounts Review ChadM 03/09/09 04:20AM
  Re: Peter's motobecane engine mounts craigery 07/04/07 10:26PM
  Re: Peter's motobecane engine mounts Fifty2One 07/04/07 11:32PM
  Re: Peter's motobecane engine mounts vic 07/04/07 11:40PM
  Re: Peter's motobecane engine mounts Joel Corvine 07/04/07 11:42PM
  Peter's motobecane engine mounts brystheguy 07/05/07 12:08AM
  Re: Peter's motobecane engine mounts peter 07/05/07 12:11AM
  Re: Peter's motobecane engine mounts tortuga2 10/03/07 08:33PM
  Re: Peter's motobecane engine mounts andrewhed 07/05/07 12:18AM
  Re: Peter's motobecane engine mounts peter 07/05/07 12:25AM
  Re: Peter's motobecane engine mounts andrewhed 07/05/07 01:12AM
  Re: Peter's motobecane engine mounts Anthony K 07/05/07 09:27AM
  Re: Peter's motobecane engine mounts No Ped Steve 12/04/08 07:14PM
  Re: Peter's motobecane engine mounts maitland 07/05/07 01:57AM
  Re: Peter's motobecane engine mounts mabecane1978 07/05/07 08:57AM
  Re: Peter's motobecane engine mounts JCampbell 07/05/07 09:40AM
  Peter's motobecane engine mounts jerry76 07/05/07 12:21PM
  Re: Peter's motobecane engine mounts peterman 07/06/07 01:34AM
  Re: Peter's motobecane engine mounts Brett Walker 07/06/07 01:42AM
  Re: Peter's motobecane engine mounts peterman 07/06/07 01:51AM
  Re: Peter's motobecane engine mounts Mike Bartell 07/06/07 02:16AM
  Re: Peter's motobecane engine mounts Creature Van 10/03/07 08:45PM
  Re: Peter's motobecane engine mounts Bret Hoffman 10/03/07 09:04PM
  Re: Peter's motobecane engine mounts jimbo 10/04/07 02:46AM
  Re: Peter's motobecane engine mounts steve 10/03/07 09:20PM
  Re: Peter's motobecane engine mounts Graham Motzing 10/04/07 02:53AM
  Re: Peter's motobecane engine mounts peter 10/04/07 02:59AM
  Re: Peter's motobecane engine mounts Ratbiker. 10/04/07 03:04AM
  Re: Peter's motobecane engine mounts steve 10/16/07 06:15PM
  Re: Peter's motobecane engine mounts peter 10/16/07 06:25PM
  Re: Peter's motobecane engine mounts Arran 10/16/07 08:00PM
  Re: Peter's motobecane engine mounts Erin L 10/16/07 10:46PM
  Re: Peter's motobecane engine mounts Graham Motzing 10/16/07 08:24PM
  Re: Peter's motobecane engine mounts peter 10/16/07 09:52PM
  Re: Peter's motobecane engine mounts Arran 10/16/07 09:55PM
  Re: Peter's motobecane engine mounts Graham Motzing 10/16/07 10:44PM
  Re: Peter's motobecane engine mounts Arran 10/16/07 11:03PM
  Re: Peter's motobecane engine mounts peter 10/16/07 10:45PM
  Re: Peter's motobecane engine mounts Graham Motzing 10/17/07 02:36AM
  Re: Polyurethane Mix Arran 10/17/07 04:53PM
  Re: Polyurethane Mix Bert 10/17/07 05:53PM
  Re: Peter's motobecane engine mounts JCampbell 10/17/07 10:51AM
  Re: Peter's motobecane engine mounts steve 10/17/07 11:08AM
  Re: Peter's motobecane engine mounts Crackstar X 10/17/07 12:04PM
  Re: Peter's motobecane engine mounts JCampbell 10/17/07 12:17PM
  Re: Peter's motobecane engine mounts Peter 10/17/07 01:14PM
  Re: Peter's motobecane engine mounts JCampbell 10/17/07 01:29PM
  Re: Peter's motobecane engine mounts Bert 10/17/07 04:15PM
  Re: Peter's motobecane engine mounts steve 10/17/07 04:57PM
  Re: Peter's motobecane engine mounts Bert 10/17/07 05:18PM
  Re: Peter's motobecane engine mounts JCampbell 10/17/07 05:23PM
  Re: Peter's motobecane engine mounts Bert 10/17/07 05:30PM
  Re: Peter's motobecane engine mounts steve 10/17/07 05:43PM
  Re: Peter's motobecane engine mounts steve 10/17/07 05:45PM
  Re: Polyurethane Mix Daniel 03/23/08 05:22PM
  Re: Polyurethane Mix Bert 10/17/07 05:57PM
  Re: Polyurethane Mix peter 10/17/07 07:11PM
  Re: Polyurethane Mix steve 10/17/07 09:24PM
  Re: Polyurethane Mix Bert 10/17/07 09:58PM
  Re: Polyurethane Mix steve 10/17/07 10:20PM
  Re: Polyurethane Mix peter 10/18/07 05:19AM
  Re: Polyurethane Mix JCampbell 10/18/07 10:01AM
  Re: Polyurethane Mix steve 10/18/07 12:34PM
  Re: Polyurethane Mix JCampbell 10/18/07 12:37PM
  Re: Polyurethane Mix Bert 10/20/07 08:57PM
  Re: Polyurethane Mix peter 10/20/07 09:27PM
  Re: Polyurethane Mix Bert 10/20/07 10:07PM
  Re: Polyurethane Mix Arran 10/21/07 02:30AM
  Re: Polyurethane Mix steve 10/20/07 10:29PM
  Re: Polyurethane Mix peter 10/21/07 02:23AM
  Re: Polyurethane Mix Bert 10/21/07 10:22AM
  Re: Polyurethane Mix steve 10/21/07 11:38AM
  Re: Polyurethane Mix Bert 10/21/07 01:25PM
  Re: Polyurethane Mix JCampbell 10/22/07 10:01AM
  Re: Polyurethane Mix Terry 10/27/07 08:51PM
  Re: Polyurethane Mix Terry 10/28/07 09:18PM
  Re: Polyurethane Mix JCampbell 10/22/07 10:03AM
  Re: Polyurethane Mix JCampbell 10/22/07 10:04AM
  Re: Polyurethane Mix keller_stephen 10/29/07 02:28AM
  Re: Polyurethane Mix steve 10/22/07 10:26AM
  Re: Polyurethane Mix Bert 10/22/07 11:39AM
  Re: Polyurethane Mix JCampbell 10/22/07 12:06PM
  Re: Polyurethane Mix Chad Burke 10/23/07 07:52AM
  mounts Bert 10/27/07 08:18PM
  Re: Polyurethane Mix steve 10/27/07 09:17PM
  Re: Polyurethane Mix peter 10/27/07 11:28PM
  Re: Polyurethane Mix Loren 06/16/08 01:39AM
  Re: Polyurethane Mix Bert 10/28/07 12:26PM
  Re: Polyurethane Mix steve 10/28/07 09:42PM
  Re: Polyurethane Mix finny 03/23/08 11:07PM
  Re: Polyurethane Mix steve 03/23/08 11:11PM
  Re: Polyurethane Mix Daniel 03/24/08 03:45AM
  Re: Polyurethane Mix finny 03/24/08 11:19AM
  Re: Polyurethane Mix Cory K 07/22/08 07:25PM
  Re: Polyurethane Mix Mike Alanko 07/22/08 07:44PM
  Re: Polyurethane Mix Jay 07/22/08 07:47PM
  Re: Polyurethane Mix steve 07/23/08 01:40AM
  Re: Polyurethane Mix Mike Alanko 07/23/08 02:01AM
  Re: Peter's motobecane engine mounts mopedjay 07/23/08 02:08AM
  Re: Peter's motobecane engine mounts sheila 07/23/08 02:09AM
  Re: Peter's motobecane engine mounts mopedjay 07/23/08 02:19AM
  Re: Peter's motobecane engine mounts bert 07/23/08 10:01AM
  Re: Peter's motobecane engine mounts Bret Hoffman 07/23/08 03:45PM
  Re: Peter's motobecane engine mounts pepilapeau 08/27/08 10:25PM
  Re: Peter's motobecane engine mounts saturn 08/27/08 11:43PM
  Re: Peter's motobecane engine mounts educatetheyouth 08/28/08 07:59AM
  Re: Peter's motobecane engine mounts Paulvolio 08/28/08 11:18AM
  Re: Peter's motobecane engine mounts Jeff 12/03/08 07:39PM
  Re: Peter's motobecane engine mounts peter 12/03/08 08:54PM
  Re: Peter's motobecane engine mounts Southern Dandy JCams 12/03/08 09:08PM
  Re: Peter's motobecane engine mounts elliot 12/03/08 09:08PM
  Re: Peter's motobecane engine mounts Jeff 12/04/08 01:23PM
  Re: Peter's motobecane engine mounts Southern Dandy JCams 12/04/08 01:49PM
  Re: Peter's motobecane engine mounts Tony Plush 12/04/08 02:30PM
  Re: Peter's motobecane engine mounts nick 12/26/08 09:14PM
  Re: Peter's motobecane engine mounts PAULVOLIO 12/26/08 09:26PM
  Re: Peter's motobecane engine mounts jaym 12/26/08 09:31PM
  Re: Peter's motobecane engine mounts sheila 12/26/08 09:36PM
  Re: Peter's motobecane engine mounts Motobee Goode 02/22/09 05:06AM
  Re: Peter's motobecane engine mounts Leo Heyman 02/22/09 10:46AM
  Re: Peter's motobecane engine mounts Gym-Me IRE 02/22/09 11:43AM
  Peter's motobecane engine mounts Review Jesse Stephenson 02/22/09 11:15PM
  Re: Peter's motobecane engine mounts Review peter 02/22/09 11:58PM
  Re: Peter's motobecane engine mounts Review Jesse Stephenson 02/23/09 12:07AM
  Re: Peter's motobecane engine mounts Review Graham Motzing 02/23/09 12:24AM
  Re: Peter's motobecane engine mounts Review peter 02/23/09 12:27AM
  Re: Peter's motobecane engine mounts Review Motobee Goode 02/23/09 01:18AM
  Re: Peter's motobecane engine mounts Review peter 03/09/09 03:51AM
  Re: Peter's motobecane engine mounts Review Justina -+:| 10/06/09 01:06PM
  Re: Peter's motobecane engine mounts Review Dwight 10/06/09 04:23PM
  Re: Peter's motobecane engine mounts Review peter 10/06/09 04:40PM
  Re: Peter's motobecane engine mounts Review Ryan B 10/06/09 07:01PM
  Re: Peter's motobecane engine mounts Review Mick Baltards 10/07/09 10:54AM
  Re: Peter's motobecane engine mounts Review timo 10/07/09 11:06AM
  Re: Peter's motobecane engine mounts Review Downhill Nater 09/30/10 04:17AM
  Re: Peter's motobecane engine mounts Review briton bees 09/30/10 08:29AM
  Re: Peter's motobecane engine mounts Review jOHNNYdOUBE 09/30/10 10:46AM
  Re: Peter's motobecane engine mounts Review ChadM 09/30/10 10:59AM
  Re: Peter's motobecane engine mounts Review Phil Norath [MMP] 09/30/10 04:38PM
  Re: Peter's motobecane engine mounts Review Adam 10/12/10 01:41PM
  Re: Peter's motobecane engine mounts Review WillD SWOOP 10/12/10 01:52PM
  Re: Peter's motobecane engine mounts Review cristian 01/24/11 01:04AM
  Re: Peter's motobecane engine mounts Review Gary Herrisch 01/24/11 01:18AM
  Re: Peter's motobecane engine mounts Review deathplaybanjo 01/24/11 01:24AM
  Re: Peter's motobecane engine mounts Review PAULVOLIO 01/24/11 08:57AM
  Re: Peter's motobecane engine mounts Review IRE Rick 01/25/11 09:45PM
  Re: Peter's motobecane engine mounts Review Phil Norath [MMP] 01/26/11 12:55AM
  Re: Peter's motobecane engine mounts Review scooterstl 01/26/11 01:21AM
  Re: Peter's motobecane engine mounts Review scooterstl 01/26/11 01:22AM
  Re: Peter's motobecane engine mounts Review scooterstl 01/26/11 01:26AM
  Re: Peter's motobecane engine mounts Review scooterstl 01/26/11 01:30AM
  Re: Peter's motobecane engine mounts Review scooterstl 01/26/11 01:33AM
  Re: Peter's motobecane engine mounts Review Phil Norath [MMP] 01/26/11 01:25AM
  Re: Peter's motobecane engine mounts Review Phil Norath [MMP] 01/26/11 01:39AM
  Re: Peter's motobecane engine mounts Review Pusher Aaron 01/26/11 01:27PM
  Re: Peter's motobecane engine mounts Review scooterstl 01/26/11 02:02PM
  Re: Peter's motobecane engine mounts Review IRE Rick 01/26/11 08:01PM
  Re: Peter's motobecane engine mounts Kurt Muzio 07/03/11 04:36PM
Click here to login.
