Re: yamaha qt50 speed kit
Jon /
The following is a post that I just made to another thread. In short, here's what I did to my QT50 to make it a little bit peppier. This posting echoes Fred's post to some extent, but I was lucky that my dad had porting experience. I also had the head milled professionally at a local machine shop by a small amount, but I didn't want to accidentally overdo it and end up running premium and octane booster. Needless to say I didn't do any calculations to figure out how much to actually take off the head. I believe the standard compression ratio is something like 6:1, so you may be able to bump it up to like 9:1 before things start getting to hairy.
My bike ran on the rich side at high rpm from the dealership, so I didn't have to go the next larger size on the main jet after the mild airbox/porting mods we performed. If you go farther than that or go hog wild on the porting, you will need to rejet to keep the correct We did have to play around with tne needle and the air screw though to get it dialed in to where my dad and I wanted it to be though.
If you have any questions, I'd love to help you out more...
(from other thread)
Well I can tell you how to get some more speed, but it requires some work. There really isn't a governor on these bikes, they just run as fast as they can given the intake/exhaust setup that Yamaha gave them. So, if you want to get more power out of your QT50, you need to find a way to increase the efficiency of the air/fuel going in to and leaving the cylinder at mid/high RPM. Keep this principle in mind. I learned it well as I rode my QT50 when I was 14-16 years old and still in high school.
I consider myself fortunate as my dad was very knowledgeable about how 2-stroke engines run and what you need to do to make them "breathe" better. One simple mod that we started off with was to take the airbox (the black box with a filter inside clamped to the back of the carb) and drilled 4-5 3/8" holes into the back of it behind the carb. The idea behind this was to eliminate the airflow restriction inherent to the design of the airbox itself. Picture the maze that the incoming air had to follow just to get to the carb. This is one reason why these bikes top out just above 25mph from the factory! Now imagine what happens when you put these holes in the back of the airbox. Now the air can flow in from the back of the airbox, straight through the filter and into the carb. (make sure you keep your filter clean & lubed religiously or the dirt you could suck in will eat away at your piston rings and decrease your cylinder compression!!) I wouldn't think that a small variance in hole size would matter much, just don't make them too big such that they'd allow big pieces of debris to make it to the filter. Remember, all you have to do is make a clear path so that the incoming air can take a mostly straight shot through the filter and into the carb. Just from this mod, I gained power throughout the RPM range, and I was able to leave other QT50s in the dust off of the line and at top end at will...even in instances where I was 40-50 pounds heavier than the other rider. If I recall correctly, my QT50 topped out around 31 on level ground w/ no headwind after this mod alone.
The next easiest thing that you can do is slap on an expansion chanber. I got a mid-top end pipe from DG that was made for the QT50. Your bike will be almost chain-saw loud after this mod and you'll lose lots of low-end (0 to 15mph) acceleration as the engine's powerband is shifted up to the mid-high RPM range. Once it gets on the pipe though, hang on! When I grabbed a handful of throttle when on the pipe (anywhere above ~18mph for mine), that tiny chainsaw motor meant business! What a ride it was! I can't believe that my county/town cops never approached me concerning its legality in my state given how much louder it was. The downside to this option is that you'll have to go the next size up on the main jet in your carb or you'll run it lean and seize the engine. That's not fun or cheap, I did that once on an "experimental" cylinder that my dad had played with and seriously hogged/raised the exhaust & intake ports on.
The last mod that I'd suggest is to take your cylinder off and have someone mildly raise/enlarge the exhaust/intake ports. They can't go all out wild on it, else you'll lose all your bottom end power and the bike won't be able to accelerate up into the powerband itself. They just need to make the cylinder "breathe" better at mid/high RPM. Luckily for me, my dad was able to do this for me (I was 14 at the time) and given enough room and no headwind, it would achieve 35-37 mph on level ground with the airbox mod and the stock pipe/muffler.
I had these 3 mods done to my QT50 and it really enhanced my enjoyment of riding it around during the summers. I put perhaps 15,000 miles on this bike (the plastic speedo/odometer housing in the front hub failed after about 9,000 miles due to these speed mods), and I cannot stress enough of the importance of taking care of your air filter and making sure you keep that oil reservoir full. I never ran into overheating problems, nor did I ever have a mechanical breakdown because I kept up on its maintenence. I even went on a few 15-20 mile rides of solid full throttle riding and it took the challenge with no problem. Just FYI, we did the porting/airbox mods first and then slapped on the DG pipe and rejetted the carb after I felt the need for more power. In the end, I was able to get the QT50 consistently up into the 35-40 mph range even on slight uphills, and I was able to almost hit 50 going downhills and also by catching a lucky draft from an SUV on level ground (which was probably one of the dumbest things I've done in my life so far). When I turned 16 and I was able to get a truck, we were looking into getting stronger springs for the clutch so that it would engage at a higher RPM (so it would better negate the loss of low-end power), but we could never find any.
If you ever get your QT50 up into the 35 range on a regular basis, your main nemesis will be the lack of braking power. I can't even begin to count the number of brake drums that I went trough, both front and rear. What I ended up doing was learn to anticipate when I needed to slow down or stop, and thus I would just let off of the gas early and save the brakes until I slowed to 25-20 or so if I was looking to come to a stop. This cut down on the brake bill dramatically.
Well, I hope you and others find my experience useful. It was a heck of a lot of fun and cheap transportation for me before I could get a car...if you have any questions or comments please feel free to email me!
Jon Dea
  yamaha qt50 speed kitTopic by: ben ben 05/22/02 08:14PM
  Re: yamaha qt50 speed kitRe: david f martin david f martin 05/22/02 08:27PM
  Re: yamaha qt50 speed kitRe: Wayne Wayne 05/22/02 10:25PM
  yamaha qt50(Yahama Expert Please?)Re: Wayne Wayne 05/23/02 09:32AM
  Re: yamaha qt50(Yahama Expert Please?)Re: Scott Scott 05/23/02 10:06AM
  Cutie ModsRe: Fred Fred 05/23/02 01:59PM
  Re: Cutie ModsRe: Joe Hunt Joe Hunt 06/19/02 11:56PM
  QT modsRe: Fred Fred 06/20/02 12:25AM
  Re: Cutie ModsRe: Bob Bob 10/01/02 06:20PM
  Re: Cutie ModsRe: Joe Hunt Joe Hunt 10/01/02 10:01PM
  ryan please click hereRe: Nick K Nick K 06/29/03 03:20PM
  Re: yamaha qt50(Yahama Expert Please?)Re: ryan ryan 08/28/02 08:56PM
  Re: yamaha qt50(Yahama Expert Please?)Re: Nick K Nick K 06/29/03 03:20PM
  Re: yamaha qt50 speed kitRe: Jon Jon 05/24/02 03:47AM
  Re: yamaha qt50 speed kitRe: Jon Jon 05/24/02 03:50AM
  Jon Rocks-- Brakes Question...?Re: Wayne Wayne 05/24/02 09:57AM
  QT-50 speed kit (Jon Rocks!!)Re: Wayne Wayne 05/24/02 09:50AM
  Re: exhaust & brakesRe: Jon Jon 05/24/02 01:01PM
  Yamahopper QT-50 info etc.Re: Wayne Wayne 05/24/02 07:02PM
  wow, thanks...Re: Jon Jon 05/25/02 01:15AM
  Re: wow, thanks...Re: Wayne Wayne 05/25/02 02:14AM
  question.....Re: darkcastle darkcastle 10/07/02 11:02AM
  Re: Moped StereoRe: Wayne Wayne 10/07/02 11:20AM
  Free Manuels?Re: Josh Josh 10/23/02 06:14PM
  Re: Qt 50 manual online? needs URLRe: Wayne Wayne 10/23/02 06:33PM
  Re: Qt 50 manual online? needs URLRe: Alexander Schwager Alexander Schwager 11/13/04 02:16AM
  Re: yamaha qt50 speed kitRe: COREY COREY 10/23/02 11:46AM
  Re: yamaha qt50 speed kitRe: Alexander Schwager Alexander Schwager 11/13/04 02:09AM
  Re: yamaha qt50 speed kitRe: Kyle Guerrette Kyle Guerrette 03/08/05 11:01PM
  45 mph QT50 buy parts todayRe: Paul Paul 07/15/02 02:22PM
  Re: 45 mph QT50 buy parts todayRe: Wayne Wayne 07/15/02 05:37PM
  Kevlar brake pads and stiffer clutch springs!Re: Alex Alex 07/24/02 04:16PM
  I got manuals for yall on the net for FREE!Re: Alex Alex 07/24/02 04:25PM
  QT50 mods and testsRe: Fred Fred 07/24/02 04:38PM
  Re: QT50 mods and testsRe: Alex Alex 07/25/02 04:35PM
  Re: QT50 mods and testsRe: ken R ken R 07/27/02 09:35AM
  Re: QT50 mods and testsRe: Al Al 07/27/02 11:35AM
  Re: I got manuals for yall on the net for FREE!Re: Vito Vito 09/20/02 03:37PM
  Re: I got manuals for yall on the net for FREE!Re: Matt Matt 09/20/02 08:34PM
  Re: I got manuals for yall on the net for FREE!Re: Anthony Anthony 10/05/02 09:08AM
  Re: QT wiring diagramRe: Wayne Wayne 10/05/02 08:27PM
  Re: Cutie ModsRe: david f martin david f martin 10/01/02 08:36PM
  Re: Cutie ModsRe: Bob Bob 10/01/02 09:16PM
  Re: Cutie ModsRe: david f martin david f martin 10/02/02 08:48PM
  Re: Cutie ModsRe: Mark H. Mark H. 10/02/02 09:20PM
  Re: Cutie ModsRe: david f martin david f martin 10/02/02 09:34PM
  Re: yamaha qt50 speed kitRe: GRMPer GRMPer 10/23/02 04:32PM
  Re: yamaha qt50 speed kitRe: Nat C Nat C 07/13/03 07:38PM
  Re: yamaha qt50 speed kitRe: Adam Reinke Adam Reinke 08/03/03 10:24PM
  Re: yamaha qt50 speed kitRe: Trucks Trucks 08/30/05 05:54PM
Click here to login.
