Slipping Clutch Fix
Hey I just found out why I had to pedal like hell trying to start my Jawa recently. Clutch was not engaging low pedalling speed. I had a leaky petcock for a while and somehow gas/oil mixture got into the clutch assembly, which is right under the petcock. So the 2 stroke oil was lubricating the clutch, making it slip.
If you have slipping clutch you might want to try degreasing the clutch. Since it's so cold out I didn't want to use water based cleaner. Instead I used electrical contact cleaner spray from auto parts store. It washes off grease and evaporates quickly.
Masa
Masa
| Subject | Written By | Posted |
